what else could be wrong - brakes
DSRTRDR
I can mangle anything ...
Baton Rouge, LA and Fountain Hills, AZ
Symptom: brake light stays on after release of parking brake, and goes out when brake pedal depressed.
Checked: rear drums adjusted (one was stuck); wiring o.k.; master cylinder connectors o.k. (resistance increases when brake pedal depressed; also checked with a new one); fluid levels apparently o.k. (cannot find a leak); brakes do work. Brake switch on pedal looks o.k. - is there something that can get stuck or worn out?
What else do I need to check? Thanks in advance, Claudia
Do you hear the brake light switch clicking on and off when the pedal is pressed and released? Do you have the pedal return spring hooked up?
yes on both questions.
Oh, I didn't read the part about it being a parking brake problem. I don't have a light for the parking brake. My best guess for this situation though would be the switch. Is the there power constantly going through the switch? If so then maybe something inside the switch broke or is stuck.
Claudia;
Normal operation is pull safety on, light goes on. With safety brake pulled on; push on brakes and light will go out. Its in the way the stop light switch is designed as best as I can tell from FSM 98154.
With your situation, I am thinking the brake pedal is not adjusted correctly. If u have the above FSM, see page 8-2 for adjustment ... I think the stop switch is being slightly depressed, causing what u see.
dfm
The brake warning light can be activated either if the parking brake is on or if there is a pressure differential between the two sides of the master cylinder. This is caused by a leak; either external or inside the master cylinder. Removing the light bulb is ignoring the problem, which could be a serious one.
my cruiser has a dual master cylinder system, no prop valve (front disks, rear drums).
I kinda like the light exactly for the reason that it does indicate if there is brake trouble (which is how we found the stuck drum in the first place).
yes. If both connectors are pulled, light is off.
update... just installed braided lines in place of the rubber ones between frame and axles, and in the process of bleeding the brakes I noticed that when I release pressure at the rear by opening the bleeder screw, I can hear the front calipers release (yes, hear - must be a special Wilwood/Man-it-ain't-free feature... ). Unless I misunderstand what a dual circuit brake system is all about, this would point to an internal leak in the master cylinder - thanks, Pinhead, for the diagnosis.
