Nothing too exciting... But drove the 460 miles to bring the big gal to her new home. Had to leave her up north when we moved, did recon Friday and Sat. Let the rebuild begin...View attachment 909980
She made it! Now time to set up a meet n greet
Later on I'll trim the rear and weld up the inner fenders so they attach to the outer. But for now, at least I can drive it
I bought it a while back of fleabay for $50. Manufactured by Davtron for small aircraft. You will need a 24v to 12v step down inverter, couple of bucks on fleabay as well.Where did you buy that? Outside temp has been on my list for awhile.
Phil,
Thanks and yes - I'm a visual guy so any pics of the mount at the floor would be very helpful.
Best,
J
Started as a Jotto mount for the laptop. The arms give the ability to place it just about anywhere and any angle you want. Making swinging the laptop out of the passengers area easy. The Jotto is top line product with many attachment mounts available. I removed all mounts but the main tube, welded a stop inside the tube, and a flange on the bottom. By mounting using only the post between the console and seat in does not make the passenger unhappy. Drilled straight down and inserted a long grade 8 3/8" bolt that goes through a couple layers of a sheet metal beam and out the bottom. A plate to add strength under the body of the sheet metal and tighten the grade 8 bolt. The post mount has zero movement or flex.
I made a coupling out of some spare Jotto parts to eliminate the arms. I still have the ability to tilt, raise, and lower the mount.
View attachment 910547 View attachment 910553 View attachment 910554 View attachment 910556
Continuing with the interior and electrical
What is the liner product name you have used? Looks really clean!Continuing with the interior and electrical
Decided since my 8 and 10 year old girls don't smokeI'd take this:
And Since their idea of a day in the Land Cruiser is an Ipadand other devices I'd Make this:
Sized up some lights for my roof rack build
https://forum.ih8mud.com/threads/sierra-ancha-tour-w-forest-personal-6-26-2014.810411/Great pics Tools R Us
Great pic's!
