- Joined
- Jan 6, 2012
- Threads
- 342
- Messages
- 10,979
That stinks. At least it made for good picsRear driver slipped and it fell in.
I used mine to mock up and test a new starter kill switch kit I will have on the site for pre orders sometime in the next 10 days or so. The best part is that it requires no wires to be cut. Easy to install and easy to remove.
I suspect this will work on a myriad of Toyota's but have yet to confirm that. It does work perfectly in the FZJ80's.
This kit will include everything needed to install a starter kill switch WITHOUT cutting any wires. 50amp relay, marine wiring, basic on/off switch, etc. Once installed you will have the ability to disable the starter by the simple flip of a switch. The kit requires disconnecting the starter solenoid wire, connecting our kit, mounting the relay, and using the included fuse tap for an 'ignition on' power source. After that, just mount the switch at your favorite hidden location. I also give enough length in the switch wiring that you can mount the switch just about anywhere within reach of the driver. I would have pictures of it installed in my rig, but I am not going to share that detail
More to come.
View attachment 2774304View attachment 2774305View attachment 2774306
Leads many to add one? I’ve never heard of anyone doing that. Besides there has to be one already. All that current isn’t going through the dash to the key.Okay, maybe you already covered this but one of the issues with the 80 series is that there is no starter relay, leading many to retrofit one. Could this kit be made to perform this function and have the interrupter as a side benefit (or is this already the idea)?
Thank you for posting this. This is only my second week owning a LC and didn’t know this was a thing. I’ll check mine first thing in the morning!Got a not so friendly reminder to check my nuts (and bolts) before AND AFTER wheeling.
I stopped as soon as heard and felt the caliper rubbing. Rim could have been a lot worse.
Let us know how it goes! Might need to do this myself.
That’s just lack of giving a **** right there. Wow.A poorly executed v8 swap in an 80.
View attachment 2776487View attachment 2776488View attachment 2776489View attachment 2776490View attachment 2776491
Cheers
Are you going to make it better or do a different motor?A poorly executed v8 swap in an 80.
Cheers
Source for the headlights?Got some more elbow grease and kitten cut & polish into the winter coat.. original paint still holding strong! Also received my Depo Sahara headlights, just waiting on the corners now!
Are they pressure cracks? How’s the barrel.. might be time for some new metal lolNo big deal - replaced this one all by myself.
Missing since PO owned it. Anyone know if i can put center caps on this still with these rims?
Thankfully no, I thought so for a moment as well. Streaks of dirty oil/grease from the missing cap after driving it home. Just pulled it out of the garage so the steaks are facing up now.Are they pressure cracks? How’s the barrel.. might be time for some new metal lol
Building a rep @SNLC at taking on some heavy duty issues and resolving them. Solid workUnfortunately it is a fairly recent swap. The Cruiser runs good, drives alright and has lots of power. It obviously needs some love where corners were cut. We already flipped the front driveline and checked for clearance issues. The swap had no charcoal, tank line in engine bay was vented to atmosphere and the result was major gas stink in the Cruiser. We fixed that by installing a charcoal canister. Drivers door window was in-op, we fixed it by a tear down and clean plus greased.
It’s a nice Cruiser, built by a so-called Cruiser shop. This was an expensive swap. It’s a shame they didn’t fit the truck accessories which give better clearance. We will get it worked out, we are definitely not starting over.
Cheers
