Parked on my hill and burped the coolant, went for a spin, checked everything over and went for another drive. So far so good, no crunching or grinding noises and all fluids staying on the inside. Head gasket and timing chain slippers - DONE.
Love those wheels!Parked on my hill and burped the coolant, went for a spin, checked everything over and went for another drive. So far so good, no crunching or grinding noises and all fluids staying on the inside. Head gasket and timing chain slippers - DONE. View attachment 1417817
Looks just like the Narva one I got, 12 fused outputs in two banks of 6, and 12 return attachments with a common connection, such a good idea having everything at one central location. I'm using the two separate positive input banks for running off secondary battery, and running off tertiary battery/solar, so anything that needs to stay on can come off the solar sideGot the Blue Sea mounted and hooked up to switched power. So far I have only installed a 12v plug and USB setup inside the center console and on the back of the center console.
Like everyone has said that has installed one...absolutely nice to know where to hook something up now. Now I don't have to worry when adding things.
I didn't ground the Blue Sea bc I am grounding each accessory wherever it will be mounted.
eBay link for all the infos 12 WAY FUSE HOLDER BOX NARVA 54450 SUITS ATC FUSES | eBayThat's a great idea, I'll have to swap out my single 12v Blue Sea block for a homemade version of the double positive input setup. Maybe I should just buy one of these.
How many quarts did you add during that 5,000mi interval?As I suspected...
No blown HG but definitely something going on in the top end. Hoping it warms up soon...
View attachment 1418232 View attachment 1418233
As I suspected...
They look like these.@SeaJay who's castor plates are you running ?
Looks like 4 qts in 5,500 miles. Burning some oil huh?
IIRC these engines had a 300,000 mile before overhaul useful life. Someone correct me but I think Toyota sells the "overhaul" ones that are slightly larger sized pistons and/or rings.
I missed that. I just find it odd they will run a report against averages with that being a variable.
