This is in my future:
Proto Torque Wrench, 30-150 ft.-lb., CW/CCW J6015C | Zoro.com
The UPS truck...I mean...Santa's sleigh...got high centered in the church parking lot. Ned drug it back up until he got traction. Ned saved Christmas!
what are mufflers?Fixed my muffler...again. Pismo did a little damage but not too bad. Nothing my neighborhood muffler shop couldn't band aid.
Order a 1992 cdl switch to day ($76 at a memphis dealership) and the cover for the fuse panel $13. The lady said there was only 2 fuse panel covers in the states and that they may not fill my order for it. I hope they do, it's ugly seeing the fuse block all the time.
Switch will be here tomorrow, so I plan to install it and do the 7 pin mod this weekend!
From my harrowing experience from turkey day...The short of it is I suspected my Craftsman torque wrench. I was going to send it out to a calibration shop in Burbank but I didn't feel like spending the $35 and driving out so I just used the method from the link I posted.
Here are current numbers on my torque wrench (Listed /Tested) in ft/lb:
10/10
20/21
30/33
40/44
50/58
60/70
70/88
80/101
So what's the issue? I have been retorquing my lugnuts over and over and over and over again at 101ft lb. On top of that everything else I've been using my torque wrench on has been off. It turns out the problem is me and specifically the tools I have been using. I'm tossing this Craftsman pile of s*** and spending the money to get a good one. This of course means ALL of my wheel studs are suspect now.
Officially 3X Locked! First time and it locked right up! At the dealership today they had record of "front locker wiring melted, removed" from 1997. 19 years and it popped right off.
View attachment 1366774 View attachment 1366773 Can someone snap a pic of where the front locker wiring harness routes? I got it connected but have an absurd amount of leftover harness. The harness is wrapped to protect from heat but not sure how that area would be near the exhaust. And have no idea where the clips pop in to.
Thanks.
Awesome. Can't wait to see a ton of pics from your upcoming trip!
Santa came early for my Land Cruiser. Set of five BFG A/T KO2. No more slipping and sliding!
Nice, started trying to put my receiver hitch on today and was unable to get the factory tie downs off....Makes me curious to how they built this, was the plate bolted on first and the round stock loop welded on after? can't get a socket on it without cutting on the round stock loop..here's a pic, thoughts?Had some HD tow points made up.
J
View attachment 1366793 View attachment 1366794 View attachment 1366795
Both rears are bent to the same degree, maybe in shipping or some overzealous tow truck driver did it.... I started to pound a 3/8 17mm socket on it but thought better of it without researching, there's no way my impact socket would go on there without relieving the round stock, now that I see @reevesci 's bomb proof mounts i'll relieve it and change em out.... hint hint 4 of em should work well with what we have going... @reevesciIt appears to be bent. Should be able to get a socket with an extension on it easily.
Thanks for the reply. I'm considering swapping over to some Slee 4" rear springs. Are the mediums you speak of the SOF4RM ?
