What could it be?
Botswana Africa
Howzit
I have a 5 speed manual 3F FJ62,
It has recently started - when I clutch in between 4th and 5th I get bad vibrations, feels like I am hitting ruts at 60mph. It also happens when I am de-accelerating from around 70mph. It only happens at these times, and it goes away when the engine torques again.
Any ideas would be a great help.
Also battery light wont go off even with fully charged battery.
:rolleyes:
Sounds like your driveline is out of balance, either that or you have a u-joint about to let loose! Unless you knocked a balancing weight off its probably the joint-when was last u-joint service?
I would have to agree with hicruise55. It sounds like a bad u joint.
Had similar problem at about 60 mph. Bolts on the drive shaft connecting to the third member had come lose.
more about the battery promblem, i got the same thing going on with the light...
Thanks Guys
I will get it checked out asap.
battery thing still bothering me, I think its time for a new one.:hhmm:
