water leak questions?
  • Thread starter Thread starter skunkworks
  • Start date Start date
S
skunkworks
Guest
I have some water leaking just above the driver & passenger grab rails right where there is stiching on the liner/fabric during rainy weather. Has anyone experienced this?
Also I have some water collecting in the area of the slider/step thingy below the doors...is that possible... or at the wheel well I hear it whishing back and forth when I stop and go. :confused:
The weep holes in your framerails are probably clogged with dirt. Run a nylon brush along the length on the inside portion. If you don't get a gush, crawl under and look for the weep holes. When you unplug them, be sure to keep your mouth closed.
Kalawang
Kalawang
Ditto that
and the water leak is from the sun roof.
This is one of 3 things.
1. cloged drain tubes
2. bad or old rails each rail is about $300 just in parts
3. old sunroof seal- you can not get just the seal you must buy the glass and seal this is about $700 again just for parts this cost me about $1300.
We did #1 and 3 and it still leaks
good luck
:cheers:
Sam
