- Location
- United States
Hi folks,
missed some ponys inside my good old 12ht so started to search for them.
As I had checked and ruled out many other possibilities before I focused on the boost compensator.
The culprit is most definitely in the diaphragm itself. Not enough movement in it. ....my one despite feeling quite allright seems to be a bit on the stiff side and has probably hardened out as it did not pass the test which is described in the manual: Apply 1.36 bar or 19,7 psi and achieve 4-5 mm of movement at the rod. If less discard the entire boost compensator.
My one is way off - I can only achieve a max. of 2.8 mm stroke when I applied the 1.36 bar with the guide bushing turned so far out that the spring just hold a tad pre tension.
The parts catalogue is showing only 22013-68151 which is the basicly whole top part of the govenor, I don´t know whether this is still available - but for sure it is or was rather expensive.
After searching the net for a while I found exactly nothing about it.
So my question into the world is: Has anybody replaced that diaphragm with an other part or knows the Denso part no.?
As my 60 is still going quite well - (it freed up many ponys reducing the pre tension on the diaphragm by turning the so called guide bushing 3/4 of an turn out) - i´m looking for annother old one to show it at the Bosch Denso Keiki Zexel or Lucas shops around.
Maybe someone has done it before and knows already more...?
Cheers from downunder
