Overland Tailor
Boltripper
- Joined
- Jun 24, 2012
- Threads
- 81
- Messages
- 1,142
- Location
- Birmingham, AL
- Website
- www.overlandtailor.com
The Overland Tailor Visor Organizer eliminates the mess of receipts, pens, note pads and miscellaneous items that plague our trucks. The organizer is a perfect way to get things just where you need them.
Made with all U.S. Sourced Materials and Overbuilt with 1000D Cordura, Mil-Spec Hook, Loop and Webbing, the organizer is guaranteed for life. Loop panel on the front for patches along with 1" webbing spaced per PALS specifications. A Kevlar/Poly zipper pull can be tucked into a webbing slot to keep the zipper from dangling when you drive!
Designed with (3) attachment straps, our organizer stays put and doesn't sag like a granny when loaded with gear.
Use the code MUD10 for 10% Off~
More information can be found here:
Overland Gear and Equipment
Compromise Elsewhere~
- Available in Overland Tailors standard colors (Black, Medium Gray, Ranger Green, Coyote and MultiCam)
- All materials are U.S Made, Berry Compliant with the exception of the YKK zipper and pull (Japan)
- The organizer fits the 80, 100, 200 Series. 70 Series fits test is pending~
