Vintage Air at Cruiser Corps
Hello: I want to install a vintage air system in my ls1 v8 powered 1976 fj40. Can you provide an entire kit for that? Would it have the compressor brackets, belts and whatever else is needed. Is it a simple install? Thanks, Ed
Ed,
Your LS setup is no problem. You simply just order the system and add a note stating your type of engine and we'll make sure you get the correct bracket system (lower mount.) It pretty much comes turn key ready to go.
It's not a simple install no, on a scale from 1-10 it's around a 6. It's just time consuming but if your mechanically inclined and know your way around your FJ40 you should have no problem.
