RCV PERFORMANCE
The Last Axle You'll Ever Need
Manufactured in the U.S. using only high-strength chromoly materials, RCV Performance Ultimate 30/30 spline CV Axle set simply replaces your 80 Series Land Cruiser's weak axle shafts with a high-strength design. The factory axles were designed with 30 splines at the differential, and neck down to a corse 24 Spline at the CV creating a common failure point. This axle set upgrades the weak 24 splines at the CV to a 4340 30 spline race eliminating the need to neck down the shaft. We have gone a step further by upgrading the inner shafts to 300M, which provides an even greater tolerance to stress. Tests prove Ultimate CV Axles to be twice as strong as OEM shafts, and they're just as tough at a straight angle as they are at extreme angles. Even if you have big tires and big power there are no worries. Ultimate CV Axles are low maintenance and operate with a smoothness you can feel - whether off road or on the street. And we back it all with a "No Questions Asked" limited lifetime warranty.
Axle set includes right and left inner axle shafts & 2 pregreased CV joints. Optional nickel plating is available for extra corrosion resistance in salty environments. We can accommodate custom length inner shafts - contact us for details & pricing, or use our Custom Axle Configuration Form.
Ultimate CV Axle Set for Land Cruiser 80 Series ('91-'97) - 30 Spline 300M Shaft Upgrade
