Build Tucker and Roma's 75 FJ40 Restore
So after some more engine hunting I found the holy grail. an HZ from a Saudi 105 series land cruiser with only 12k miles on it. To top if off the truck it was pulled from was 12volt already so that made it that much easier.
new bell housing test fitted
we also decided the weight of the hz is a little too much for the harbor freight engine stand and since I have a couple of 12ht's to go through next that it was time to get a real engine stand. This one is geared so you can single handedly rotate the heavy inline sixes.
Currently the engine is on the stand and despite the extremely low mileage the engine is probably at least ten years old since the last 105's rolled off the assembly line in 2007 soo we are doing some preventative on it by means of all new seals, belts, water pump, and thermostat.
Wow. Your work is always awesome.
Making some more progress on the engine, finally got the new dust seal for the new timing cover and new timing cover bolts so was able to button all that up last night. New belts for the alternator but apparently the a/c belt we got was too short so will need to get another one. Front side of the engine is finished up with the exception of the a/c belt.
Also go the engine off the stand and the powder coated engine plate back on. rear main seal replaced. Clutch literally looked brand new with machine marks still on flywheel so we reused those. New throwout bearing and clutch fork and along with the new bell housing.
need to source the dust plug that goes on the right side of this housing to plug the hole
The shifter boot we got is for a cast iron clutch fork so need to get one of those and also the correct clutch master cylinder.
Engine is ready to be mated up to the trans.
I love seeing how the manufacturers solve their engineering challenges. The Toyota set up looks kind of similar to the Land Rover system, except the Land Rover uses just one belt to run all three. GM uses a chain and a gear. Ford uses a mongo chain. Datsun/Nissan uses a belt. Cummins a set of gears.... each have benefits and detriments.... interesting to me. Thanks for posting the pictures.
We have been working on the body sandblasting, repair, and painting in parallel with the frame and engine work. Below are pictures of scrapping the insulation off of the driver side prior to sandblasting and trailering the tub to get sand blasted
We ordered replacement passenger and driver side floor panels (due to rust issues) and a rear seal from Realsteel. Note the passenger side replacement floor panel is flat without the concave interior gas tank space. We plan to put only auxiliary tank under rear of tub and so we removed interior tank.
I had the hood repaired because it had blown up at some point while being driven and had crease it and bent spine. The spine was removed and straightened. Then it was tacked on ends and seam sealer was used along the spine to reattach like original.
We moved the original gas filler hole from front to rear and raised it into the wheel well to try and prevent spillage while turning. On my previous build it had an aux filler hole at low level (below fender well) and it tended to spill when turning. Attached are pictures of interior and exterior modification.
