Trailer Axle Anatomy 101
Shahram
I ain't got herpes no more.
TEHRANGELES
As a complete and total layman in the area of trailer parts, I find I have some difficulty searching for the right parts for my off-road utility trailer project. Frankly, I don't know what parts are under the trailer, much less how to find replacements for them.
This is what I do know:
--The axle housing is a 2"x2" square tube, with a flat, four-bolt plate on either end. It is leaf sprung.
--The hubs are four-lugs.
I'd like to, if at all possible, replace as little as I can to get some larger wheels and tires on this thing. Optimally, I'd like to have the same lug pattern and tire size on the trailer as I do on my Cruiser (OEM 6-lug 16" wheels with 285s), but I don't know if it's possible without replacing the entire axle, something I'd rather not do. I know I have to replace the hub and possibly the spindle assembly, but what parts should I be looking for?
Also, what kind of axle is this, and how much capacity could it possibly have?
Sorry for the child-like questions, but I'm completely clueless here.
Thanks for any and all advice.
Here is a place to start......................
http://abctrailerparts.com/axles.html
Pilfered from someone else's post:o
Ed
"Child-like questions?"..............Hell we are all about "Child-like " questions;>)
Looks like a lot of sources are already posted so I'll share what I have discovered about trailer axles.
The temptation might be to simply flip the axle over re-attach the springs and replace the hubs, this does not work. Why? Because the axles is built with a slight bow that flattens out under load to get the correct camber on the wheels. If you flip the axle you will have a negative camber which will ruin the tires.
Right now I am convinced that a torsion axle is the best type for an off road trailer. There are a few that allow you set vary the preload to match your payload. But with no first hand experience I could be swayed in this opinion.
