Longfield Chromoly Rear Axle Shafts
Big tires and low crawler gears can and do lead to broken rear axles. If you are looking to upgrade your
drivetrain, check out our Longfield Chromoly Rear Axle Shafts. These axles feature a break strength of
8,300 ft-lbs of torque and up to 120 degrees of twist.
Note: The Longfield Chromoly Samurai Rear Axle Shafts are made specifically for our Rock Assault
Samurai Rear Axle Housing
Available Options:
Longfield Chromoly Rear Axle Shaft, 79-85, Single, 303470-1-KIT, $145.95
Longfield Chromoly Rear Axle Shaft, 86-95, Single, 303471-1-KIT, $145.95
Longfield Chromoly Tacoma Rear Axle Shaft, Single, 303472-1-KIT, $145.95
Longfield Chromoly Samurai Rear Axle Shaft, Long, 141033-3-KIT, $145.95
Longfield Chromoly Samurai Rear Axle Shaft, Short, 141034-3-KIT, $145.95
Longfield Chromoly Rear Axle Shafts, 79-85, Pair, 140178-1-KIT, $282.45
Longfield Chromoly Rear Axle Shafts, 86-95, Pair, 140179-1-KIT, $282.45
Longfield Chromoly Tacoma Rear Axle Shafts, Pair, 141042-1-KIT, $282.45
Suzuki Manual Locking Hub
Genuine replacement Aisin hub that will fit your Suzuki Samurai, Sidekick, Jimny and more. The Suzuki
Manual Locking Hub will come with a hub gasket and cover hardware. Sold individually.
Application Data:
1986-1995 Suzuki Samurai 4WD
1986-1995 Suzuki Sidekick
1986-1995 Suzuki Sidekick, X90
1986-1998 Geo Tracker 4WD
1986-1998 Chevrolet Tracker 4WD
1989-1998 Suzuki Escudo, Vitara
1990-1995 Suzuki Jimny JA11
1993-1995 Suzuki Jimny JB31
Suzuki Manual Locking Hub, 302256-3-KIT, $103.95
Continue reading...
Available Options:
Application Data:
Continue reading...
