80's adapter
8 tack from @Trollhole i think
68' radio non tlc
8 track
View attachment 1256209 View attachment 1256210 View attachment 1256212 View attachment 1256213
Agreed. I'd buy one.
That's not at all like the tool kit that came with my '78 new. It was a zippered bag with the tire iron, a couple of wrenches, a spark plug tool, a screwdriver or two, and the jack handle. That looks like an earlier kit.
Is anyone making these zippered bags? Mine is a little ratty looking...
formerly "Refurbishing an
Early Tool Roll"
Toyota Land Cruiser Tool Kits
Large Tool Roll - 23mm (58-6308)
Large Tool Roll - 21mm (6308-65)
Large Tool Roll - 21mm (66-6903)
Medium Tool Roll - Canvas (6903-7103)
Medium Tool Roll - Vinyl (7104-7203)
Zipper Bag -TEQ Yellow (7204-7901)
Zipper Bag - TEQ Brown (7901-8210)
Zipper Bag - Toyota Motor (8210-8309)
Links to Land Cruiser Tool and Tool Kit Threads
Tools / Tool Kits / Options & Accessories - Index - Specific topics of interest relating to tools, tool kits and other early Land Cruiser items.
OEM Tool Kit Inventory - Additional information about tools and tool kits. Includes a link to the Inventory pdf that details Land Cruiser tool kits through 1984, and includes criteria to help identify the kits and the tools included with each of the kits.
Land Cruiser Tool Kits Album - Images of Land Cruiser tool kits from IH8Mud, e-Bay, and elsewhere.
Land Cruiser Tools Albums - Images of Land Cruiser tools from IH8Mud, e-Bay and elsewhere.
Toyota tool catalog: “Recommended Tools and Checkers”
Refurbishing an Early Tool Roll
In early 2013, I had this large tool roll refurbished, and stocked with new Toyota tools.
While the body of the roll and the pockets and loops were in fairly good shape, the top, bottom and side flaps were not. The outside of the flaps appeared to suffer from exposure to sun and moisture. The fabric was bleached, weakened, and easily torn.
Working with local canvas and leather designer Rusty Zylstra (Mercy Supply, Grand Rapids, MI) the tool roll was repaired and recovered. Rusty did a great job repairing the tool roll and making the changes needed.
The plan was to keep the body of the tool roll and replace the top, bottom and side flaps with new, waxed canvas. Keep the original buckle, but since the strap was quite worn, replace it with a canvas or leather strap. Repair the loops and pockets as needed and adjust as necessary to fit the new tools. Since the binding was worn through and falling apart in some areas, replace it with a leather binding, and cover the outside of the roll with leather for added protection.
With a new set of Toyota tools, the refurbished roll looks great.
The Refurbishing Process
Preparing the new top and bottom flaps. Rusty was able to clean and reuse the Contents List window.
Every tool loop was re-stitched and backed with leather, to address weakness due to canvas dry rot; it won't rip in the corners any more.
Two copper rivets attach the strap and buckle.
Full leather outside and trim, with a Horween leather strap.
Stocking the Tool Roll
A refurbished tool roll needs the proper tools.
With the exception of the wrench clip and grease pump, these are all new Toyota tools. Most are service tools, available in Japan, but not in the U.S. The wrench clip is from KTC, purchased on eBay. The Toyota grease pump (Yamada KH-120, part number 09170-00030) pictured above dates from around 2002 and is no longer available.
The small Yamada KH-120 grease pumps with the ring/chain are available from online sellers. The current look is different than the earlier one. The pump has a satin silver finish instead of gold, and the handle says MADE IN INDIA. Still marked YAMADA although the mark is now on the top of the head instead of the side. The pump comes with the straight nozzle, a bent nozzle (CNP-2) is available.
When stocking an old tool roll with new tools, consider that the dimensions of new tools may be different than the originals. This is especially true of the screwdrivers. The handle sizes are larger, and the handle material is more difficult to slide through the canvas loops. It was necessary to resize the #8 and #9 loops to fit the new screwdrivers. The original roll had two rows of stitches between these loops. Fitting the screwdrivers involved removing these stitches, adjusting the loops to fit and re-stitching with a single row. Test fitting the actual tools in the vintage roll ensured a proper fit.
Ordering the Tools
The Toyota tool part numbers can be found in “Recommended Tools and Checkers”.
There are several ways to order parts from Japan. Using Amayama Trading (www.amayama.com), it took 25 days to receive the parts. Amayama uses a multi-step order process: initially enter part number and descriptive information, Amayama confirms the availability and pricing for the parts and provides the shipping cost, confirming at this point places the order.
I need to find the later clear bag for the new light. They are still available from Toyota but don't come with the bag.
Soak in peteol, diesel or kerosine and scrubbwith brush. When clean soak in warm water several times to get rid of smell ..The zipper bag material is vinylized canvas. I use Simple Green all over the outside to remove the grease, oil, dirt. Use a soft bristle brush with a light touch. Then go over it again to spot clean areas that need additional attention.
After that, put the bag in a tub with mild laundry detergent, like Woolite. Go over the inside and the binding with the brush, and let it soak for 30 min. Rinse completely. Re-shape the bag and use balled-up tissue paper at the ends to hold the shape.
To dry, place the bag up-side-down over a small narrow box (a small USPS flat rate box works), sitting up on its long edge and let it air dry.
I've not been able to completely remove the black stains on the outside of these bags caused by the black rubber hold-down band. Tried several things that did not work.
Use a different approach and lots of caution for canvas tool rolls. These are difficult to clean because the canvas/binding may be weak due to the effects of age, exposure to UV, moisture etc. The fabric becomes quite brittle and is easily torn or damaged. Since canvas will shrink when wet, and this may further damage the tool roll, washing is not recommended. Even if the tool roll is not damaged further by washing, the loops and pockets may shrink such that the tools no longer fit. I use a small vacuum brush to remove loose material from the canvas, and leave it at that.
