Toyota Tools
The card in this one has a few differences than the ones posted earlier
A couple close ups of the Engine Adjust Kit (4 pocket that doesn't have the red points file). I thought it was cool the voltage tester still has the wax on it.
That's not at all like the tool kit that came with my '78 new. It was a zippered bag with the tire iron, a couple of wrenches, a spark plug tool, a screwdriver or two, and the jack handle. That looks like an earlier kit.
Here's my 1978 tool bag with a few battle scars
full
full
full
3/69-3/71 – Medium Roll (Canvas)
- roll-up canvas w/strap - olive drab - TEQ TM - 2 styles of marking:
-early kit - TEQ far left of strap, TM right of strap (TEQ positive image)
-later kit - TEQ TM right of strap (TEQ negative image in black square)
09120-60010
Agreed.
Well aren't we a bit OCD!:confused: This is the tool kit that came with my 1978 FJ40 back in 2011 and I was not the original owner.:flipoff2::hillbilly:
Y'all make it sound like I committed a :censor: crime:hillbilly:
Just pointing out that it's an earlier tool roll, that's all. If you hadn't called it a 1978 tool bag, I wouldn't have bothered to say anything.
Thanks Geezer!:cheers:
Large Tool Roll (early) - OEM (vintage tools)
This is the early (1958-63) version of the large tool roll, designed to hold the 2-piece lug wrench. The early version can be identified by the top #3 and #4 loops that are not aligned. This version includes a Maruki hammer and 6 open-end wrenches with oval handles held by a blue TEQ wrench clip. The adjustable wrench is marked TOYOTA TEQ MOTOR along with an oval pad near the bottom of the handle. Screwdrivers are marked TOYOTA MOTOR on the shank, the grease pump is marked TOYOTA TEQ MOTOR and the engine adjust kit green pouch is marked TEQ.
full
In addition to the lug wrench, the pliers and spark plug wrench are much different from later versions. This pliers has a plain screw, a reinforcing ridge on the jaw, no KTC PAT mark, and curved handles with triangle grips. Later pliers have a slotted screw, U-shaped reinforcement, KTC PAT mark, and re-curved handles with dimpled grips. The spark plug wrench has a thicker wall and a recessed rather than formed end.
full
This version of the spark plug wrench dates from around 1962, same time frame as the Four Wheeler FJ40 review that included this photo of the tool kit.
There appears to be three versions of the these early, curved handle pliers, this is the second version. Earlier pliers (1958-59) have a much smaller TEQ mark and do not appear to have any reinforcement on the jaw. Slightly later pliers (1963) have a slotted screw, U-shaped reinforcement, dimpled grips, and the KTC M.PAT mark on the back.
full
This pliers has an unusual "6135" forge mark.
full
Detail of the reinforced jaw.
full
Unmarked on the back.
full
Nested triangles grip. Inner handles are not marked, dimpled grip TEQ pliers are maked MADE IN JAPAN on the inside of both handles.
full
Comparing these pliers to subsequent versions; 2nd from 1963 Large Roll (23mm), 3rd from 1964-65 Large Roll (21mm), 4th from 1969 Large Roll(21mm).
Both the jaw reinforcement and screw type changes with the next version. Re-curved handles are introduced with the Large Roll (21mm).
full
The KTC patent mark appears on the next and following versions as M.PAT, finally changing to PAT by the last version.
full
The next version changes to the dimpled grips with the MADE IN JAPAN mark.
full
Spark plug wrench is marked TOYOTA MOTOR on the front, 20.6 in back, with the horizontal line.
full
full
More robust than the later spark plug wrench.
full
full
The Content List calls this the 23mm Hub Nut Box Wrench. The wrench is marked TOYOTA MOTOR, no JAPAN or MADE IN JAPAN mark, the handle is unmarked.
full
full
full
Comparing the early 23mm wrench and handle with the later (starting 1/79) 21mm 2-piece wrench.
full
In addition to the 23mm Hub Nut Box Wrench specification, the Content List for this 23mm tool roll is noticeably different than this 21mm tool roll list.
Thanks for all you contribute to this thread. It is one of most enjoyable and informative threads on all of MUD!
wow, the older tools are a lot better quality than the later stuff ... thicker walls on the plug wrench, the grips on the pliers ... nice, and ditto re your work on this thread ... my 78 toolkit is almost done, thanks to your research ...
:cool:
This is the early (1958-63) version of the large tool roll, designed to hold the 2-piece lug wrench. The early version can be identified by the top #3 and #4 loops that are not aligned. The early version includes a Maruki hammer, open-end wrenches with oval handles, and the adjustable wrench is marked TOYOTA TEQ MOTOR along with an oval pad near the bottom of the handle.
full
full
Where did you find that one?!
WOW, just WOW. You fells certainly have the details down. I am happy to live with my non-detail self !
Kudos to all the research and posting on here. One of my favorite threads so far.
As always great stuff here..................
