For Sale Toyota 1282B 'Seal Packing' Silicone - Heat Exchanger Cover Sealant
Car Guy
Longmont, CO
This was purchased for the infamous leaky heat exchanger cover (see pictures below). This sealant is highly recommended by Toyota and rumored to be an updated formula from what was used at the factory(sub-par). I used far less than 25%. This was $104 at the local dealer. Also included are the 2 necessary 0-rings(Toyota OEM) for the associated coolant crossover pipe. I bought two extra incase of any issue with installation but didn't need them. $65 shipped for everything to anywhere is the 48 states. That is basically half of retail. Use what you need and sell the rest. Please private message me if interested.
View attachment 2204758View attachment 2204759View attachment 2204760View attachment 2204761
Has the foil seal been breached on the tube tip / have you used some out of this exact tube you are selling ?
or
did you buy a extra tube as your description suggests that is still sealed ?
thanks for the reply ......
matt
Description is pretty clear he is selling one tube opened and partially used along with two o-rings.
It looks like I may need to do this repair sooner than later as I have some pink residue on the backside of the engine :(
I speak from experience with this repair. The leak had been slight for a long period of time and then got much worse very quickly. If you can see or smell any coolant, this is bound to happen eventually.
