Tire Pressure Monitor
Colorado
TPMS does not show which tire corresponds to the particular tire pressure reading with exception to the spare. Anyone here know the tire sequence on the TPMS?
There is not set sequence from what I understand. It is whichever tire contacts the system first as to which order they show up in....stupid I know :)
Yup, DTT is correct with one exception: There is an order to it, but it's cumbersome.
Once a TPMS sensor inside the valve stem contacts the system, it will always stay in that position on the screen. However, if you move that tire to another area, like a tire rotation, it will reconnect to the same spot on the screen, but be in a different location obviously.
So, the way to figure it out is to deflate a tire and remember (or write down) which location on the screen it is. Do this for all tires.
When you get a tire rotation, you need to know which tire went where, or just do it over again.
If the vehicle looses power, however, I believe this resets.
