Tire pressure for stock 18"s
Kansas
Before you say use the search, I have. For you guys with stock 18s, what tire pressure do you use for normal driving? Door says 33, truck came at 41? Don't know if the dealer set it at 41 or didn't check. Thanks for your help! I am not really concerned about ride but even tire wear.
Gene
That's the shipping pressure. They pump up the tires pretty high so the don't flat spot while in transit. The dealer must have forgotten to set it properly.
Stock p-metric run at 33.
When I had the stock 18" tires, I used the recommended 33 psi per the door label.
► Alaska 2011 LC200 / Silver / 285-65-18 BFG All Terrain TA/KO ►
