Build Tippy is back…hopefully
Ha! 2” body lift probably not necessary but I bought it like that and wasn’t planning on taking it off and fighting it. The radiator is good and in now so not really wanting to redo that. We probably going to run 35” tires and might go larger later on.
Was wanting to go 37” or 38” tires but didn’t want to regear now. It’s a really rough trail truck so plans are get it reliable and drive it and not worry about trail damage.
It may even be a 3” body lift.
I bought it like that as well with some worn slap out 38” maxxis gumbo mudders lol
I’m thinking I ran it with no shroud? Rad was off center of fan but I never had any issues with overheating. Amazed how well the 1F did on hwy with the big tires. Talk about rubber overdrive.
This thing is SOA isn’t it? Should be able to easily run 37’s on a low/medium slung SOA.
It might be more effort than you were originally planning, but getting rid of the body lift might help the Tippy Bitch not be so much of a Tippy Bitch. Plus the added bonus of not having to deal with Jerry-rigged radiator mounts and steering shafts and the like.
What is the deal with the radiator not lining up and why is that piece of tubing there?
Is there something wrong with the mounting of the inner-fender/core-support assembly (some people call it the “doghouse”) , either on the firewall or out front on the frame? Is that upper bracket a homemade job also?
^^^ x2!!!
I was reading about those and thinking, "What in the Sam hell?!?"
@RUSH55 It’s got a 2” body lift so the radiator had to be moved down. Metal is rusty below headlight area etc and pretty sure this pig has been on its side so nothing really lines up. The only brace I noted is the 1” square tube going from the firewall to headlight/radiator support.
Ah, so in other words she has been "gently used"...
That stupid support had to come out for 1F>2F swap….. but it made for a good hood prop rod lol
Impressed...didn't even pull the hood!
Yeah @scrapdaddy it is probably my favorite of what we have. The other 2 are straight plows. So sitting up high and the V plow makes it nice. Ironically it was the one I was most concerned about and it and the salt spreader worked great. Both spreaders went down on the other trucks and we had one solenoid break on the other plow. The snow is sticking around here because of the temperatures.
Jason
Jason
Sounds like your timing is great!
We ran it for the longest time today for the first time. Smoked a little more than I would like. We chased down some oil leaks. It doesn’t have the power I think it should have. We were watching the temperature with a laser temperature gauge since the gauges don’t work yet. It’s got a 2f from a friend’s pig that wasn’t quite right and over heated once that I remember. I put a new head gasket on it. So we will see. Engine sounds good. I’m going to adjust the valves and then do a compression test and see what we have.
