Third row electric seats (1 Viewer)
Panama city, Rep of Panama
I have a 5.7 V8 2008 Limited with electric third row seats and electric rear gate
Problem is the driver's side seat on the third row...it goes down fine but doesn't stay down (beepin all the time), I have to let go of the button...when it goes up, it stops and will not recline as much the other side
I read somewhere about a rubber, but I have no clue on where it is and what was the person referring to
Could someone here help me?
Thank you
have seen many times where a coin or debris is blocking the gear
+1
Did this occur all at once, or gradually become a prob?
Are you 100% “ I got in there myself w/ a bright - a$$ flashlight & there was nothing “ - that nothing is stuck in a mechanism, like a coin or some other random, like a bit of a child’s toy?
Or are you still in the cursory “search forums & see what other peeps probs” - were?
Hit the low hanging fruit, maybe even shop vac or air compressor whatever you can see looks like part of the moving stuff.
Got plenty of time to see it (we are in lockdown here) have done nothing to it, I bought it about 5 months ago, was working fine but the left side kept beeping, now the left side goes down and up, but will not recline, that is the issue, the right side works flawlessly
And yes, also searching if any have had the same type of problem that I have, so far nothing
Will dice into it tomorrow, will let you know if I find anything blocking it
I have a similar issue in my 08, driver side. It will continue to beep when its all the way down. It will finally shut up but the light on the switch stays orange. The seat seems to lay flat and even with the right side while down. I removed the floor mat, inspected everything and found no obstructions. Following.
Well...in the end, what I did was change a switch from side to side...dont know where to get them from because I believe it's better to change all 4 of them, the ones in the front not by the tailgate
