Build The Warthog - 1977/73 combo
Packed and ready except for cold items and clothes.
swapped the tent over and climbed all over and checked bolts and fluids.
One loose belt and low PS fluid.
Ready for Thursday morning to go to the Swine Soirée
Just read the entire thread. Wow, talk about some trials and tribulations! Excellent revival. Mike
Pigs are a beat down. In the end it’s worth it but the journey Can be a challenge
1040 mile trip. Zero issues. It’s unreal to know this turd was 2 even bigger turds two and 1/2 years ago.
Can’t wait till SSS20
Finally got this Green Weenie 40 running so I could move the Warthog into the shop and see what it needed after the massive trek to SSS19
It took a sip of engine oil, a bit of PS fluid, lots of grease and I drained the front diff since my breather hose came off.
It may have had a tiny bit of water in it, but it was not milky.
A little touch up paint on the sliders and that’s it. It’s ready for the next adventure whenever that is.
I was feeling real bad at the Swine Soirée when I was following @Voodoocruisers with those dopey Stark LED headlights.
Beno turned me on to some Toyota Koito H4 headlamps and I bought a set for a 40 I’m building, my 40, 55 and 45.
kit comes from Toyota with 2 lamps, 2 bulbs and a wiring harness to upgrade your stock harness. It’s basically plug and play if you have the correct ends for battery. I had to put larger hoops on mine.
I did a bulb test in this thread. Page 3
Yeah... Me: "89? In that? Are you kidding me?" :)
