Build The Warthog - 1977/73 combo
See this compartment? Nothing looks out of place like it would with a swap.
So backing up with the story.
Added new plug wires and dug out the dobber and wasp nests.
Added Marvel and Sea Foam to the plugs and carb and let that sit 24 hours.
Shot either and bam. 10 years later it runs.
that IS a 77 firewall, as opposed to a 73, the heater blower and cut-out give it away...wow...might be a roof graft...moot point, really, as the most important part is the doors WILL work afterall...
Plans.....farm beater. Just wanted to combine these two and make one. I'm stoked about having a Pig again. I think I can make it whole. Rusty POS whole but whole.
I drug the 73 parts Pig to my shop and dug in.
I never imagined I would intentionally bolt piece of s*** fenders like this to a vehicle but it sure beats none. The last owner spot welded the upper fenders to the inner fenders so I had to grind them off.
Of course there were 2 bolts per side that kicked my ass and stretched the job at least an hour.
The doors from the donor are solid. The rears are fully functional but the fronts needs guts.
I have the side glass and the windshield covered with the parts Pig. Who sells the rubber?
So I guess we can expect you at the Pig Fest this June?
Rust Converter Aerosol
This stuff is GOLD!
Used it for my 1968 Patina project. Really awesome product.
This time I'm not just going to use it on the underside and frame. It's all going to get a coat then a cheapo paint job over it in the end.
Treated rust turns black and its dead. I used to use POR 15 and this is way way easier.
