The 80-series doesn't seem to be a weapon of choice for towing.No it wasn't. It was long, ca. 275 mile, drive back at 50-55, sometimes 45. Time for a real tow rig.
I bet that MB diesel isn't light either...
Thank you sir, but I believe I’ll hold off for now. These bumpers are kinda ugly, but they are also welded straight to the frame and very solid. I’m probably going to just weld a receiver to the rear and leave it. This Pig isn’t going to be pretty anyway.I have an original rear bumper you can have if you decide to go back to OEM. It's missing one of the ends but otherwise fine. Of course you have a decent matching set on there so you might want to just keep those.
somehow from that conversation Jerry asked me if I wanted his Pig
Haha. Thanks Jim!I need friends that ask me questions like that. Congrats Gavin!
100%!!!I need friends that ask me questions like that. Congrats Gavin!
At least to start with, pretty easy to change hubs after *everything else* is doneIf the Warns work den WTF. Keep em![]()
I'm sure that will work but I would have been tempted to use a rust converter that you can paint over, like Corroseal.Very little to report on the Pig. I picked up this ‘72 FST on Friday from a guy who was either nuts or on coke. It has a disc brake front axle that I will be swapping under the Pig when the time comes. View attachment 4107697
The axle has Warn hubs on it, and I’m one of those people who prefers the Asco/ Aisin hubs. Now, the Long Body Asco hubs are very hard to find and expensive, Cityracer sells reproductions of these hubs. Are the Cityracer reproductions as strong as the factory Asco/ Aisin units?
I also Fluid Filmed the roof since all the paint has been stripped by the sun and it’s started to get pitted. I’m planning on painting at least the roof for protection.
I thought about using Rust Convertor however I don’t have any at the moment, Fluid Film was readily at hand and it’s better than a bare roof. When I paint it I’ll sand it down to bare metal to remove all surface rust so that it will be years before I have to think about it again.I'm sure that will work but I would have been tempted to use a rust converter that you can paint over, like Corroseal.
There are a few places where there are some holes, but I’ll worry about that later.Glad it only surface rust. Hang on to dat Woomin
They’re in a few areas I believe weren’t covered with replacement pans, bottom of B pillars and a few other places. Nothing badHoles?? Thought Jerry had all dat covered wit me stuff![]()
"Everything else", LOL...At least to start with, pretty easy to change hubs after *everything else* is done
That's a good woman to spend her time sanding the Pig floor w/ you!My girlfriend helped me to sand down all the rust on the floor pans today, I then painted all the areas we sanded. I have a few areas left to go back and sand before finishing painting. View attachment 4111436
And no the above picture is not the finished product before I painted. And, yes, I painted with a brush, in the most old man way possible that I would absolutely judge anyone else for, but it has protection from more rust.View attachment 4111437
