thanxs rhino
Definitely- that was cool of you to walk though that with us. You could have had it done a lot quicker without us there so it was nice that you took the time.
Rhino Rules!
(btw- I passed everything except for the Hydrocarbons at idle on the 40 this morning at the emissions test)
Same thing here Rhino.... It was very informative. I'm still gonna take you up on helping do mine. I really don't have the tools to do the job myself... without spending a chunk of change that is. I did get a pinion seal over at BAP and tried to do the pinion seal that evening... but ran into the same propblem. Not the right equipment to 'get 'er done'. I couldn't break the bolts loose to get at it.
Anyway... thanks for the time on Sat. It was very cool of you to do the walk through.
your welcome guys, it was pretty enjoyable on my part. maybe we can do another "rhino tech" someday on other various cruiser parts.
zmac, yeah we can get together on that pinion seal.
I was wondering if you had time after work one night to look under the hood and help me identify if there is a vacuum leak or I just might need to adjust the mixture a little.
The HC is really high at idle and the CO is very low. I work just down the street from you though and it should just take a second for you to look in. I'm not nearly as mechanically inclined as you and would like your input before I start tweaking stuff.
I'll have to stop and pick up some of that Ale you like :D
will work for beer,, seems like my motto!!
yeah stop by today. high @ idle, sound like a lean mixture, could be several things. i'll hook it up to the heartbeat moniter and we'll see whats up.
Cool- I'll give you a jingle when I get off at 4 and see where you're at.
