HALP! Talk about bad timing... 94 FZJ-80 is Dead in Driveway, Stuck in Park, moving in 5 days, and I have a cast on my arm...
94trilocked
Supporting Vendor
ORF
Website
www.fordsix.com
Here's what happened...
Around easter I replaced the 2021 battery with a duralast AGM. Ran fine, has been starting right up, etc - all good for those 2 weeks. Today... ran one errand, started up fine, did my errand, got back in truck, started fine, drove home... Got home, put it in park, noticed AT/Temp gauge was on, oil light on, noticed other lights on dash on that I never seen before- nothing was overheating. Shut truck off, waited a minute, go to crank it again - gave me 1/2 a rotation out of the starter, then nothing - no lights on dash, no power - nothing. Popped hood, got a meter, battery dead - almost no volts. Disconnected battery cables, put tester on - at like 3volts. Grabbed another battery and some jumper cables. There's a heavy draw as soon as I connected to the test battery - I'm thinking starter solenoid is stuck. Put the new battery on the charger.
Called Mr. Toyota, new starter on order should be here Monday afternoon/Tuesday.
Truck won't come out of park... would be nice to push it up the driveway. I was able to get the bottom starter bolt out, thinking to bench test to see if it is indeed the starter, but that bottom bolt is as far as I am able to get because here's the other thing... my left wrist/arm is in a cast because of a severe tendon issue - grip and flexon and leverage are shot right now and can't really maneuver my left hand without pain.
Anyone around Norfolk, VA able to give me a hand - literally? At least to get the truck out of park? What else should I check?
You can manually take it out of park.
Remove the little cover in front of the gear shift, and insert something to depress the button inside.
You can also buy something to make it easier..
Thanks - worked. That pig is a heavy girl, but she's up the driveway. Definitely ordering that button when I get settled at the new address - when I popped the cover didn't look like anything in there to push... but a screwdriver got there.
