Some degree of rubbing, especially with significantly larger tires, is always expected. Depends what rubs.
Plastics, underliner, no big deal. There's nothing structural to them. They are just as easily massaged or cut away. Or let them self clearance over time. This works for most every tire to 33" or a bit above. One can give up some width to gain height with reduced rubbing.
Metal parts. Particularly the KDSS bar and upper control arm. Perhaps even fender, body mounts with bigger tires. Minor rub on extremes of articulation on say the KDSS bar at low speeds is not a big deal. Big rubs, especially if it happens at roadway speeds, or hard braking... you don't want this type of rub. This type of rubbing will be like unintentional application of brakes to the rubbing tire and create a bad control situation. It can also rip lugs off or compromise a tire.
Most of us with bigger tires - either really wide or larger than say 33.5" ish, have some degree of plastic rub at extreme of articulation. Shouldn't have any big rubbing with hard parts which are addressed by correcting offset.
LCs limits are somewhere in the 34" diameter tire range before the KDSS bar rub becomes a hard limit. UCAs can help. Going beyond that is possible with a combination of KDSS relocation bracket, Tundra arms.
LXs while geometrically the same, don't have the KDSS bar to deal with. It does have deeper step plastics, and a little metal bracket, which is easily addressed. Many examples now of LXs going a full 35" or slightly above with minor massaging of plastics, and almost nothing else.
At almost full 35" diameter tires both LC and LX can rub at the metal upper fender liner, particularly when stuffing the tires off road. Most people don't drive hard enough or don't care. Easy solutions are to shim out the bump stop, but I don't like the idea of giving up any suspension travel. Not really done on these boards, but a minor body lift, like .25"- .5" would solve this as well.
