stock FJ80 wheels
Wheels/Tires Gone!
Also have a set of tube steps that were installed when I bought my 80, will take $100 for.
Full set of flares and mudflaps off my FJ80, red in color, good shape, $100 for all of it.
Also got a single DIN stereo install kit with pocket, unknown vendor, removed to install something else, but worked just fine. I'll take $10 for that.
I'll get pics up shortly
do they have flat washers/ or cone?
What year landcruiser do you have? More pics of the rims and Pics of the tubes please.
early Cruisers had flat nuts, and later have conical nuts....if you try to mix and match, you could have some issues.
I might have the Earlier/later reversed, but you get the point.
My 80 is a '92, I'll get pics up later, not at my home comp right now.
These wheel were not available on the 91/92 FJ80. They started with the 93 FZJ80 and ended with the end of the 80 series in the US in 1997. If the center caps are black in the center they are from a 93/94. If silver then they were off a 95/96/97. The FJ80 wheel was the same as the 4Runner/Tacoma of the same era. 15" with just a little larger offset.
Thanks for the enlightenment. I was told that they were a factory option on my year LC, but I'm by no means an expert. :rolleyes:
They were on the 80 when I got it, but I liked the look of the black wheels (off my 4Runner) better so I traded them out. Now I'm getting rid of the LC wheels.
Currently the wheels are retained by normal 60* lugnuts, I put about 10K (3 rotations worth) on my 4Runner with these wheels and no problems. (not with the tires/wheels at least)
