I'm putting everything back together on the right front steering knuckle on my '90 HZJ73. So far so good for my first major auto repair project with the FSM, searches on here and a helpful neighbour. Hopefully a quick easy question for all of you with more experience. I'm using the terrain tamer seal replacement kit. For the knuckle seals my question is about the rubber seal. It has a raised ridge around the outside of it on one side. The other side is flat. Which way should it go on? Should the ridged side of the rubber seal go against the felt seal or against the steel ring? Thanks in advance.
