Steering help... (1 Viewer)
Hell! (Suburban Chicago- Plainfield, IL)
So I was digging through Marketplace ads and saw something I just had to have. A 72 Suzuki truck. You can't buy much in the way of parts and I really wasn't into the suspension that was there kind of a weird split rim design with four of the split Rim bolts holding the wheels on. Very strange.
So I decided to solid axle swap with Toyota stuff after really killing myself trying to find Samurai junk...
So now on to the actual problem. I need a steering box to replace the one that was in there. The one that came in it has no splines for the steering wheel side and I just don't like it. Too small blah blah blah.
The Box will be mounted with the steering input almost vertical so I need to make the arm go straight down to run crossover steering.... so I need a box that is from a car that has a forward throw arm with the knuckle attachment on the front. Or a rear throw arm for the knuckle attachment on the back.... or right hand drive selector shaft somehow stuffed into a left hand drive box.
Thoughts?
