steering arms
In the redwoods
I looked around and couldn't find the tork setting for the 40's steering arms. Does anyone have this number.
Thanks mucho...
What size stud?
What pattern, large or small?
What year knuckle parts?
From the F A Q <---- this is a link
Center arm?
Pitman arm?
64 repair manual says center arm:
"Tighten the center arm shaft just enough to allow the center arm to turn freely."
Sector shaft x Pitman Arm:
120~140 ft-lbs.
Sector shaft end cover bolts:
15~25 ft-lbs.
Hope this helps
I am not being mean but that does him no help at all and may just confuse him. He clearly states "steering arms" in his post and Poser has already provided a link in the FAQ to the info he needs which is not what you have provided above.
From the FAQ:
Knuckle Studs and Tie Rods (Values differ depending on the diameter of the stud)
11mm- 40 - 60 ft#'s
12mm- 62 - 79 ft#'s
Knuckle Years:
Pre 1979 were 11mm
1979 and later were 12mm
What size stud?
Hey Poser thanks for the response.
It's the 4 bolt patern on both sides. and I do believe that the PO put a 84 -89 mini disc conversion on my rig. I just looked and the socket/nit size is 17mm so I am not sure of the stud size.
I think if I tork to 70flbs I will be OK.
Just need to check the tork for Rubithon. I guess they are checking this year.
From the FAQ:
11mm- 40 - 60 ft#'s
12mm- 62 - 79 ft#'s
Knuckle Years:
Pre 1979 were 11mm
Sorry, was just trying to help.
I misunderstood what he meant by steering arm.
I will refrain next time
Cheers.
From the FAQ:
11mm- 40 - 60 ft#'s
12mm- 62 - 79 ft#'s
Knuckle Years:
Pre 1979 were 11mm
Thanks John, I was scratchng my head with that one.
Thanks though destin
