We use stranded wire because it has the ability to flex with minimal metal fatigue. As soon as you fill the spaces between the wire with solder it for all intents and purposes becomes solid wire. Crimp connectors are designed to make a durable connection and preserve the stranded wires ability to flex. They actually make a more reliable connection than solder when used with stranded wire.
Please don't take my word for it, NASA, JPL, JEDEC, and IPC have all done extensive studies on this topic. You will not find solder used with stranded wire in any space vehicle, military or commercial aircraft or any other high rel application. Google it.
Get a proper wire crimp tool. Klien, Channelock, and Greenlee all make good ones. Learn to use it correctly. You will make a better, more reliable connection and do it much faster than you can with solder.
Save the soldering iron for repairing printed circuit boards.
