semlin
curmudgeon
ok, so with lots of recent posts about weird idle results from messing with the throttle bodies on a 93-97, I have a deceptively simple question: can anyone list and describe what systems affect the start up idle on a cruiser with or without ac on? In particular what is it in the throttle body that affects start up idle, and before you say it is dirt inside the the chamber and on the butterfly, please consider that my start up idle dropped dramatically just by re and reing the throttle body to clean my EGR tube without touching the chamber and butterfly. I am wondering does unplugging the TPS or IAC maybe do something?
I am basically confused about what causes the high idle and the crazy high idle when you start with AC on. Originally I heard it was normal and just live with it and I think Idaho Doug mentioned he has had it since new. Then I discovered that removing and cleaning the throttle body can have a dramatic effect, at least for a while. Now it's back again so soon I can't believe it would be necessary to clean the TB again. Just for fun, here is the history of high idle on my truck
1. Dec 93 bought truck with 1500 rpm cold start, 1800 with AC on
2. over a year it built up to 1800 rpm cold start, too scared to try with AC on
3. removed and installed TB to work on EGR but did not touch TB itself and it dropped to 1400 rpm cold start, don't know about AC because it was winter
4. removed TB again and cleaned it, dropped to 1100-1200 cold, 1400 with AC on.
5. 4 months later and now back up to 1400-1500 rpm cold start in morning, 1800 AC on. Weirdly though, after work I start at 1100-1200 rpm even after 12 hours sitting still.
I recently tried just working the throttle back and forth with TB in place to see if that was the cure but it made no difference. Is there maybe a lubricant you can put on the throttle assembly?
