Splitcase parking brake options
@Hamachi what solution did you decide on?
I have not done anything yet. I am still looking for a full floating fj40 axle or I will use a pair of nice FJ62 axles I have in storage.. Tough decision - Ha!
Appears your FJ40 is between 68-71. Then a split case with a hand brake would be easier to run the cable from the dash. Kevin AKA Tools R Us on Mud sadly passed away. He did a dash mounted hand brake handle to the rear axle with a lever in the middle of two piece cable on Claudia's @DSRTRDR FJ40. Maybe she can supply a picture or two how Keven ran the cable to provide leverage needed?
Interested in why your wanting a full floating 40 series rear axle? If for the hand brake you obviously looking for a 8/80+. Advantage of the 8/80+ is unlike the pre 8/80 the full floating and semi floating share the same brake backing plate bolt pattern. Not sure if 60 series semi floating brake part would be a direct bolt on to a LWB 40 series 8/80+ full floating axle but should be a fairly easy mod.
Here is how I made my dash pull handle ebrake work with a fj62 axle.
that is very similar to how Kevin worked it on my truck
I can send pics to anyone interested - send me a PM
I’m running a h55 w/splitcase.
I realize about the H55F and split case. My comments about how with a handle for hand brake on dash it is simpler to add the hand brake to the transfer case verses rear axle because of how easy it is to the run cable. Claudia's cruiser is an early seventies that Kevin added a H55F/split case and a 60/62 series rear axle. The cable has a lever in the middle to help with leverage. Just trying to be helpful if you go with a rear axle hand brake. My 79 have a 8/80+ 40 series full floater with hand brake. My 45 truck hand brake will end up by where the hand brake handle ends up. On a split transfer case either handle location is easy but like the rear axle set up better. That is easier to do with the handle on the transmission hump.
What about the disc brake rear conversion with Cadillac calipers that have ebrake provision? I was thinking of doing that in a 1970 that's getting a split case, is that an alright option? I like that cable/lever/cable action people have done to retain the under dash handle.
