Split-t case parking brake conversion h55
Williamsburg, VA
I have searched...and...searched. I finally made it to the end of the Internet without finding a thread on the split t-case parking brake conversion. Does anyone have a link to a good thread with pics...I have read all the toyota manuals and it does not look that difficult...but it would be nice to see a thread.
Thanks
PS. I bought the conversion kit a few years ago...I have no idea why it's off the shelves.
Split case e-brakes set ups were on the drums of the rear axle from the factory. I would follow that road!:D
Justin
Howdy! It has been a popular option for those rigs 40s and 55s with upgraded drivelines, without axle swaps. I'm surprised if no vendor offers it. I'm surprised there are no detailed threads on it. John
maf
I think MAF does a kit but it is disc not drum, i have seen a couple posts about changing the output shaft and there being a kit of sorts for that to use the drum
Poser did one I think it might be in the FAQs for his h55 in a 40 install
check there
other than that for a 40 options seem to be---later 40 rear, 70 rear, (wider) 60 rear, or disc conversion with eldorado/toronado/riviera calipers with e-brake caliper up to 84 I think?
let us know if you get it sorted out though :cheers:
We used a kit from SOR to use the old 3 speed T-case drum style ebrake and adapt it to the FJ60 Splitcase on our '72. Pretty Damn spendy at over $500. Works about the same as old style, pretty lame, needing constant attention and if you don't engage it firmly, easy to burn the shoes.
SOR is having its annual sale right now. If you know someone in the "club", you can get 20% off.
I have a disk arrangement, same location, on my '75, installed by the PO. No idea where that one came from but if I could, I'd go that route over the SOR drum brake adapter.
Justin
Not so fast there Hoss.... you're obviously unaware that there were HJ-47s that were sold with a parking brake on the back of the split case. It's the same setup as the earlier one piece cases, just on the split case. (that said, I'd follow the axle parking brake route if I could as well)
The "kits" that SOR and MAF had were from the last of the stock Toyota had of the parts you had to change over to put the drum back there (just a different input shaft and rear shaft/speedo gear housing, and the matching drum), but those are apparently no longer available. Which is why you see no mention of it anymore on the MAF site, only the disc setup (which a few vendors sell, and apparently isn't great).
You can still find some used, or you need to do something else (like get an axle with the parking brake on it, or use one of the aftermarket disc setups).
As to installing it, just follow the manual for rebuilding the split case, but use the parts from the conversion kit you got instead when you put it back together. It's pretty straightforward.
And, since you see there isn't a specific write up on it, take pictures, and then give us a write up on it. It is tangentially addressed in one of the H55f install threads in the FAQ.
Dan
sor shows a used kit available but you still need to use some parts from the one piece case. The cost is just over $600. For that kind of money I was able to buy a semi and full floating axles with the hand brakes.
Dan
I was unaware....indeed:whoops:
Justin
Justin
Seriously, all the cool stuff just wasn't offered here...
centerlineseal: any pics of the disc setup on your '75? And you say it works at least as good or better than the original T-case brake?
Dan
If I had known it was a big deal I would have done a write up. It was very straight forward and I believe I just followed the directions in my FJ40 service manual, modified with the split case tail end.
Dan
I can get some pics later this week. It works just as well as original on my '72 and just as well as the reconfigured drum ebrake on the splitcase in the '72. I find that all of them need to be set very FIRMLY, so that one doesn't drive off with a weakly set ebrake and make a stink.
The disk ebrake does seem to hang there, unprotected tho. I most probably will fab up a skidplate for it this summer.
Pics forthcoming
No worries there Jon, you said it was straightforward, and it looks to be a no brainer for me. But I've got the camera ready for when I do the conversion on Dad's split case.
And then I'll probably have to do something different on mine...
centerlineseal: good to know. I was under the impression that most of the disc setups weren't as good as the original drum, which is all I really need to make me happy... I'll be curious if yours has the common disc setup that is sold by the various vendors today...
Dan
Pics forthcoming
I found your post while searching for examples of h55f + parking brake on the TC. I have a 1980 40 and am installing a h55f with a 40 series top. I have the e-brake setup for the split TC. did you ever post photos anywhere. did you have any problems.
Old thread alert. Looks like Dan hasn't been on here since April.
Maybe one of the guys in Treasure Valley Land Cruiser club section knows him.
NM. Wrong thread
