Spindle Replacement Questions (1 Viewer)
Northwest Arkansas
My son's 98 4Runner was hit on the driver's wheel yesterday, shearing the bolts on the lower ball joint plate and bending the spindle. I have the spindle off and have removed the inner seal from the back of the spindle. I am now stuck as to how I best remove the hub from the spindle? Press or slide hammer or am I missing something? This is our first 3rd Gen and is quite different from our 2nd Gens. The truck has ABS and I don't want to damage the ring. Any advice is appreciated...I do not have the FSM, but may end up ordering one to come with the new spindle/bearings/seals.
Thanks in advance.
Here you go, if you need any other pages I should have them.
The manual is for a 2002 but it should be the same. :wrench:
That's the ticket! Unfortunately, I have no press. Had to farm the job out, but the diagrams are going with the mechanic.
Thanks again!
