ARCHIVE Solid Preload Spacers For Toyota Diffs! - Now For Landcruiser!
Letsgomoreplaces
Gear & Axle parts for ALL Toyotas new or old...
Washington
Website
www.letsgomoreplaces.com
We now are stocking solid pinion preload spacers for Landcruiser 9.5" diffs found in fj40, fj60, BJ70 front and rear as well as rear of fj80, fzj80, uzj100.
These spacers are solid steel and designed to eliminate the factory crush sleeve (collapsible spacer) for a strong rigid setup. Another benifit is that, once set, it is set, so you can change pinion seals or flanges without affecting the pinion bearing preload.
Includes shims and spacer
9.5 LC diff:
FJ40, BJ40, HJ45, FJ55, FJ60, BJ60, HJ61, FJ62, BJ70, BJ74, HZJ75 Front and rear
FJ80, FZJ80, HDJ80, UZJ100 rear only
SK CSTLC $55
8" V6 or Reverse (4 pinion):
Rear 88-95 p/u & 4runner w/ v6, 96-08 4RUNNER, 96+ TACOMA W/ ELOCKER REAR
Front FJ80, FZJ80, UZJ100, HZJ78, HZJ79, LJ70, RJ70
SK CSTV6 $32
8" 4cyl
Front and rear 79-85 p/u or 86-95 rear, LJ70(non-turbo) & RJ70 rear, also 79-04 Hilux rear (non-turbo)
SK CST8 $29
8.4" REAR, 95-08 TACOMA (NON-TRD), ALL T100, 00-06 TUNDRA, SEQUOIA.
SK CST100 $39
Please post up a picture of the 40/60 series spacer on a Land Cruiser pinion...
Thank you.
:beer:
Land Cruiser solid preload spacers
More in stock!
Hi, sorry for posting on this old thread but I can't find which part number I need.
I want to install a solid spacer in the rear of my LJ79 which runs the factory 4.88 gears (the unique thin type crown wheel / offset pinion). Would you know which model I would need please ? the V6 or 4 cyl type ?
Many thanks in advance!
