SOA brake line routing
Kamloops, BC Canada
Website
www.shopraddcruisers.ca
Looking for good brake line routing on SOA 60 series, hard lines to soft lines on the axles.
Over springs or under?
Thanks
Rob
mine are under the springs and behind the axle....the are booty-zip-tied to the u-bolts actually....hehehe Over springs will suck if someday you need t remove a pack....
I eliminated the backing plates in front, used the shorter of the two hoses I note in the Facts corner.
IIRC, my lines are all from NAPA...
Under the springs and behind the axle here too...minor reroute but tight and secure. The hoses woody refer to make the job easy. IIRC mine came from NAPA too.
Thanks, that was what I thought but wanted to be sure of the front soft line mounts are not worth the trouble.
I did however see a set of braided lines that ran the length of both sides of the axle into the T, that looked a tad more pro. Maybe that was wagoneers truck, he does trick work.
I order two extended brake lines for 16$ a piece, I got them from Andres SOA write up.
Now the FF rear axle should be easy using hard line a small bender, double flare tool and away I go.
Thanks
Rob
