Snorkel, CAI, TRD Exhaust Installed
Northern Illinois
I thought I was finished with mods for the year, until word of the Safari Snorkel becoming available for the FJ reached my ears ...er, .. eyes.
Tacozilla works for Toyota of Houston and is an all around good guy. While ordering the snorkel from him I got a bit impulsive and ordered the TRD Cold air intake and the TRD Exhaust. They were shipped very quickly and I was ready for mod heaven :D :D :D
Any one of these installs alone was relatively easy. All three at the same time might leave you a bit thirsty :cheers:
I happened to be coming down with something, so when I started at 8:00 pm one night, by the time I finished I was just a shell of a man. I went right to work the next day and ended up being awake for 38 hours straight before I finally got some sleep.
The Cold Air Intake install was pretty straight forward. You just follow the well laid out instructions. I took my time and enjoyed the time spent with the truck.
The snorkel was just as easy. The directions make it all a piece of cake.
Of course I ran into some problems (as usually happens with a project at some point)
Problem one. I bought the wrong size arbor for my 4" hole saw :( . At 11:30 at night I discovered this. ...but being an old sheet metal worker from way back, I just drilled a hole and got my Aviator snips out (reds) and cut the circle by hand. I don't even think the fender is 18 gauge. It felt like 20 or maybe even 22 gauge. It was easy to do.
Problem Two:
The connection between the CAI and the snorkel should have been easier than I made it. I started out with a plan gone bad. The reason is; there is simply not enough space between the ARB connection hose and the CAI inlet to do very much fancy stuff.
What I ended up doing is:
I still used the full length of the ARB connector tube.
I still used the rubber seal for the CAI that you put around the CAI box inlet opening.
I ran the ARB connector tube straigh inside of the CAI box. It is a pretty good fit, but not completely air tight and certainly not water tight.
I tried a few different things with gasketing, window glazing tape, glazing rubber, door seals, etc etc.
What I ended up deciding is that the only way I can know for sure it will be air and water tight is to go back to basics. Caulk. Silicone.
I grabbed some black silicone and went around the perimter of the ARB inlet tube. It is a complete seal. It should expand and contract with the cold weather here in Chicago and it should not have to be replaced for 10 years, but I will inspect it annually just in case.
The exhaust was EASY. Buy the right tool folks, or you're going to be wrestling with the hangers way more than you need to. Both Craftsman and Snap On make what is called an Exhaust Hanger Removal Tool. You might need to order it. I had one of the guys in the shop make me one from an adjustable clamp. With it the exhaust hangers pop right out of the rubber hangers holding them.
Here is the Snap On version YA3202, Pliers, Exhaust Hanger Removal
I have 45,000 miles on my FJ, so some of the bolts were fairly rusty. You need a bit of leverage to get the bolts off if that is the case. For the second time my hi-lift jack handle has saved my skin. It is the perfect size to slip over your socket wrench handle to use for leverage.
I did end up rounding off the head of one of the bolts behind the muffler so I just grabbed the sawzall and cut it about 6 inches back of the connection.
Both old pieces came right out (no need for ramps or extra height) and the new one bolted right in place. I don't have any pictures of the entire thing (maybe today) as I was dead dog tired by this time.
My truck is breathing so nice now. I love the sound (Exhaust + CAI) and the whole truck seems to "glide" for lack of a better word. ...it's almost as if it felt bogged down, or had a sinus infection before. Now it just seems to be burden free due to the better flow of air.
Merry Christmas to me. I think I'm done with mods for this year. ....again
So what does it feel like cutting through a brand new fender? I bet you measured and re-measured about 10 times before you committed! She looks badass!
It would look better if you had s custom rack for the fuel cans you have strapped on top. I bet you are already working on that.
very nice
Thanks! ARB provides a template that makes measuring unnecessary. They really do make it easy. Knowing the finised product, it did not bother me to drill a series of 5/8" holes and one large 4" hole. I just made sure I primered the snot out of them when finished.
Bill, it all looks great.
So you too went with the 4" hole saw over the 4 1/8" one?
There is plenty of slack with the 4" hole to allow you to align up the snorkel good.
Well, I bougtht the 4" but ended up cutting it with snips because my arbor was the wrong size :doh:
Oh crap, that is right, I read that.
That is before I had my java juice :D
Looks awesome. I'm starting to get annoyed that mine isn't here yet. I called Fat bobs and they can't give me a straight answer. I'm calling tomorrow and if they can't give me a tracking number i'm canceling the order and calling man a fre. They have a bunch unspoken for ready to ship. I'm really glad to see that it can be set up with the CAI.
Also, I think it looks great with the factory rack. I don't understand why everyone is so quick to ditch it. I love mine. you can always add a front basket and make it a full rack. As far as the cost of some of the products like the garvin rack i figure if you are putting tens of thousands of mods into your rig, a few hundred for a rack isn't that big a deal in the long run.
When I talked with Steve-O a week ago, Man-a-fre had 10 left. I'm not sure where they are with them now. If you need Tacozilla's phone # just let me know.
I agree. I love the stock rack, and while I can't stand on it, it does all I need it to do.
They refunded my order at fat bobs and man-a-fre sent mine out today!
A little off topic here, but I too dig the stock rack, and it can also do this, and I am thinking of getting one.
Wow! Is that the one that ARB carries? I've seen it, but i didn't know it was compatible with the factory rack. That is SWEET! That would be really nice for a hunting trip, or a multi-day expedition/trail ride. I can't wait to get my snorkel installed and show you guys how she looks these days. I'm thinking superchip and front lockers next.
Dragon, I like your ride....:D
How easy was it to connect the Snorkel to your TRD cold air box? Any pics of this ?
Thanks
Thanks
Thank you sir.
I ran the ARB connection tube right inside of the CAI and caulked it for an air tight connection.
This is the only pic I have
