ok, so ive got a flat Belly, well the t-case hangs just a bit
id like it to go from the Flywheel all the way to the rear of the t-case..
Now ive got some ideas on how to build a Skid plate.. Here is my idea.. 1" Angle Iron Frame or SQ Tubing Frame.. Skin the Bottom with 3/16 steel, then add another 1/4" of the Plastic Poly type Cutting board stuff
Countersink some Alen head bolts to connect the two together!
Hows that sound?? im not planning on draging my truck across every rock in the country, but want good protection and piece of mind when i decide to tackle the harder stuff
Next is mounting.. I was thinking some way to make it Easy to remove, Maybe Poly bushings with Pins.. i dont know, Give me some ideas, or photos.. I dont want any Bolts hanging down to get trashed or hung up on.
