Patineto
"Clueless" fourwheel rabbit
First one...
I have seeing three mentions so far of "Broken throttle cables"
Well since the first motorcycle was invented somebody came with the idea of running a parallel cable/housing) as a easy to install spare, remember for yours motorcycle run mechanical drum brakes and the cables fail all the time..
So just to make things clear and simple, buy a spare cable set up (On most current motorcycles a throttle cable and a clutch cable) waterproof the ends some how (Condoms actually work great, then electric tape on top), then zip tie the back up line to the main line (I hate electric tape because is unreliable, but I hate even more getting my wet hands poke by zip ties, your choice)
I promise it will take you seconds instead of minutes to get back rolling..
Note: Check the ends of the housing, most cables break because the ferrules produce to much friction, brass works awesome but sometimes is just no space for it..
I hope it helps
I hope it helps
