Seat function sanity check. I could swear my seats used to... (2 Viewers)
Tennessee
Am I totally losing my mind? I could swear my seat used move away from the dash and my steering column would retract when I turned the truck off.
Its supposed to do that, right? Like to give you room to exit the vehicle, right? I'm not imagining it did that, right?
I programmed position 1 and 2 because i had surgery and really wanted to give myself a wide birth getting in and out, then hitting the other memory button to get back my preferred spot. But now it wont adjust when I turn the car on or off, return to memory position on its own
I didnt sync my FOB to the seat position. Any way to factory set the seats?
Are you using the parking brake?
I noticed the 200 platform will
Raise steering column and retract seat fully when parking brake is used but not when it isn’t.
OP: What year?
Seat you can change in customize settings but steering wheel is a Techstream or Carista customization
If anyone comes across any 3rd party physical standalone “full vehicle” OBD readers (not a phone app) that can do customizations as well please let everyone know. I know there are some for codes but not customizations.
Carista is the only 3rd party I am aware of that can do the customizations.
On my 19 it is called "Driver's Seat Easy Exit" and you can turn it on or off in the Infotainment menu. I turned mine off which is how I know, but could see why someone would want it especially if you had surgery. IIRC the steering wheel still tilts out of the way with seats off but I could be wrong and I've only had one cup of coffee so far.
This is in a 16 same way I did it in mine
I'm not. I didnt in the past either when it was "working"
OP: What year?
2021
i wonder if theres a computer glitching out somewhere. My radio will change stations every so often by itself, but always when I'm fiddling with something, like adjusting a vent or something. Something that has me questioning my sanity like "i KNOW i didnt come near the change station button on steering wheel or radio, but did I where i adjusted the mirror" or something like that
Re-save your memory slot (1 or 2), then select it again and try once more.
Thanks. I've tried a number of times. It moved correctly 1x, then stopped. At this point, i think its either 1 fob, 2 different settings, or a issue with the ECU going out or something or the settings in my seat causing a issue. Position 2 is a low as it can get. not all the way back, but maybe because theres nowhere to go on one memory setting, the whole thing doesnt work
Man, that's a weird one.
My experience has been once a change is made(seat position, steering wheel), then the next time the truck is started it doesn't automatically revert to the previous memory setting. I would need to "hit #1" for example, to set it back.
