History: I have a 1972 CB175 that I have been restoring over the past couple of years. I rebuilt the motor about a year ago and have since put 11 miles on it. I could not find suitable mufflers and it was just to loud to ride. Plus I don't have a tag yet so just I have just been terrorizing the neighborhood for those 11miles. I recently found mufflers for it and am ready to get it on the road. I have not had any issues since the rebuild until now. I should also mention that I crank it at least every week to keep things fresh.
Problem: My problem is it won't start now. Battery is good, compression is good, plugs are good, and it's getting fuel.
Question: Is there any way to test the coil and condenser? I tried using a voltmeter on the coil and the voltmeter went haywire and now the digital display does not come on. I have recently learned that you cannot use a digital voltmeter on "pulsing" power sources. True or false? I used an analog voltmeter after this and was getting 5V from the spark plug wires and the coil. Thoughts? Bad coil?
Should there be a spark between the points when they open? I am thinking there should not be, but I am new to points systems and don't know. I have new points on the way.
Is there a way to test the condensor? The repair manual states to touch the case of the condensor to the negative post on the battery and the positive wire of the condensor to the poisitive post on battery. Let it charge for a few seconds and touch positive wire to the case of the condensor if there is a spark it can be presumed to be good. I did this and nothing, both with the old condensor and the new one. Any thoughts or suggestions?
Thanks for reading all of this.
