Well everything has been running great then all of the sudden a week ago it started acting like it was was misfiring while under load. I checked all the plug wires, and replaced all the spark plugs and the issue is persisting. I have determined its firing on all 8 so I'm thinking its either the timing went nuts somehow or maybe its an issue with the quadrajet carb. Any other suggestion or help will be greatly appreciated.
Engine specs:
Gen 1 350 crate motor. Stock
Quadrajet carb
MSD 6A ignition
MSD Street Pro-Billet w/Vacuum Advance Distributor
What I have done:
Replaced plugs.
Checked all plug wires.
Checked all the fluids.
Cleaned the distributor cap and rotor with a wire brush.
What I have not done:
Replaced the distributor cap and rotor.
Cleaned the carb.
Engine specs:
Quadrajet carb
MSD 6A ignition
What I have done:
Replaced plugs.
Cleaned the carb.
