For Sale San Diego California: 2006 4runner V8 4x4
Year
2006
  1. 4Runner
Mileage
169000
Color
White
This was my dream build and I’m sad to let it go, 2006 V8 2UZ VVTI 4.7L 4WD in White with Grey interior. Clean title 169,XXX miles. Full build list is probably still missing a few things. Build list is long with Long Travel, Triple Locked, Regeared 4.88 etc.. got receipts for a lot of the mods and did a lot of the work myself.
Title in hand, message me for any questions! Price is $38,000 or best offer! I’m willing to part out and lower price if anyone is interested. Will consider trades for other built rigs. Located in San Diego California.
my instagram is @daygo4lo if you want to see more pictures or contact me
Goodies
4.88 Nitro Gears front and rear
Triple Locked with ARB Front and Rear air lockers,
Factory Center Differential Lock
TotalChaos race series 2” long travel kit
Total Chaos UCA
Total Chaos Spindle
Total Chaos Front Sway Bar
Total Chaos Cam tabs
King 2.5 coilovers w remote reservoirs F/R
King 2.0 rear bump stops
CVJ +2 Extended CV Axles
Metal tech rear full link kit (upper/lower)
Dobinsons 749v rear
Dobinsons front differential drop 1”
Dobinsons rear swaybar extended links
35x12.50r17 Yokohama Geolander G003 MT
Rotiform ROC forged wheels (5) 17x9.0 with OMF simulock conversion (drain lite outer and inner stiffening rings)
Demello front winch bumper
Demello welded sliders
Warn winch with remote solenoid, synthetic winch line
Factor 55 fairlead
CBI rear bumper w/ custom swing out for spare and rotopax mounts
RCI aluminum skids
RCI steel gas skid
RCI rear shock skids
RCI rear axle skid
Fabzone CMC
Front runner roof rack
Frontrunner quick disconnect awning mounts
Frontrunner quick disconnect RTT mounts
Frontrunner wind deflector
Frontrunner CB Antenna Mount
Rotopax relocation bracket
2 gallon Rotopax water jug and 2 gallon rotopax fuel jug
Custom TRD Pro grill
Toyota OEM Sport Hood
TRD Panel filter
Magnaflow stainless exhaust
SAI bypass
OEM white door handles
Rear Wing Spoiler w/ LED break light
Hi-Lift Jack
Clear Ceramic Tint on Front Windshield and tinted windows.
Interior
10.1” Atoto Android Headunit with Wireless Apple CarPlady
All new audio amp/speakers/wiring installed during soundproofing
install
JL audio 5 channel amp
JL audio door components (4 doors)
usb power throughout
12v access panel in hatch/prewired for fridge
LED upgrade to all interior/exterior lights
Custom white LED dash and reverse polarity HVAC lights
Rear Baltic birch drawer system
Snomaster 56l fridge/freezer
Clearview easy slide
Entire cab 3 stage sound deadening from firewall to trunk including doors
Electrical
Off grid engineering custom dual battery system
Dual setup Optima AGM blue top (marine) batteries
Blue Sea ACR
Custom Bussman auxiliary (10) fuse panel with 5 constant/ 5 switched - Contura panel mounted in cab.
ARB dual compressor mounted in engine bay
Under rack mounted renogy solar panel
Renogy MPPT blue tooth charge controller
3 gal aluminum air tank (mounted in spare location- on board air.)
Train horn kit in spare location
Baja designs-Led fogs, Interior lights in trunk/ hatch (2 red, 1 white) Rear and side 10” LED bars (on rack)
All wiring professionally done with gxl/txl wiring, weatherproof terminals, hd heat shrink, grommets and techflex loom throughout.
Recent Maintenance
Oil changes every 5k full Mobil 1 synthetic
Frame has been coated yearly with fluid fillm.
Tires upgraded to 35s @ 161k miles at discount tire
Total Chaos LT kit maintenance, all new uniballs @ 162k
New OEM Timing belt and Water pump @ 162k
Both batteries are agm blue top replaced @165k
5th gen brake upgrade in the rear, fronts wouldn’t fit because my simulock ring on the rims 🤦‍♂️ so refurbished the stock rotor with new OEM pads @162k
K&N reusable cabin filter refreshed @164k
K&N reusable Air intake filter refreshes @164k
