That's awesome. I've never doubted that you guys lived and breathed all things land cruiser even off the clock. I like seeing "behind the curtain."
Both great rigs.
I am going to crawl under there and take a picture when I get off work because I was pretty sure I didnt see a bleeder on the back. I didnt see the threded hole for a bleeder there either. But I could be wrong and just didnt see them. Like I said Ill check. I am very familiar with the 9mm brake lines as it was all that on my 1964 fj40. But I am pretty sure they are 10mm. I do remember the trick to bleed them on the 40 was to adjust the shoes out so the wheels would not move, bleed them and then adjust them back.There are bleeders in the rear and you still buy them new. At least the top number, 47547-12010, is still available; as is the cap.
You need to make sure you have 10mm fittings on the brake lines and not 9mm. I think these started out as 9mm but quickly moved to 10mm on the 40 and 55 models. Pretty sure that fitting will work as long as yours are 10mm.
Not a great photo but the bleeder should be on the front of the front brake cylinder.
Yeah Ill be honest I thought it was wierd that I didnt see a 2nd bleeder on the back side of the axle! it was like 98 degrees today so I could have just been delirious too haha.To be clear, that is the front side of the rear axle.
Look at my eBay #267249778300, 3rd photo. I can provide one of those adapters ( modified), with the machined metric Allen head bolts for $49.95. It must be used with the stock insulator board/block for clearance. Also, look at my eBay #265210899173, especially the 3 drawings, you’lol want that kit for your carb. Don’t buy any of it on eBay, I can merely send Mud members a PayPal invoice- -easy deal@Downey I have a carb question for you. If I want to run my holley 2b 2300 on my 2f what kind of adapter plate do i need. I also understand that I need to change the jets if I have a 500cfm carb?
Thanks.
@Downey Can you pm me your info? I am interested in the adapter 100% thanks! I think I read and have it written down if you have a 500cfm holley you would use #61 jets, #35 nozzle and 8.5 power valve. I saw that somwhere on mud.Look at my eBay #267249778300, 3rd photo. I can provide one of those adapters ( modified), with the machined metric Allen head bolts for $49.95. It must be used with the stock insulator board/block for clearance. Also, look at my eBay #265210899173, especially the 3 drawings, you’lol want that kit for your carb. Don’t buy any of it on eBay, I can merely send Mud members a PayPal invoice- -easy deal
@WarDamnEagle I knew I was not crazy! front side has a bleeder and rear did not on both sides of the rear axle.To be clear, that is the front side of the rear axle.
Good. That's the way it's supposed to be.@Downey Can you pm me your info? I am interested in the adapter 100% thanks! I think I read and have it written down if you have a 500cfm holley you would use #61 jets, #35 nozzle and 8.5 power valve. I saw that somwhere on mud.
huhh... I was under the impression you meant that the rear had a bleeder too. My 64 fj40 had bleeders in both the front and rear cylinders on the rear axle. I assumed that is what you are saying. this is where my confusion came from. My bad. That factory set up made it super difficult to bleed.Good. That's the way it's supposed to be.
Thats a good question. I think it stops because I can spin it by pushing the door button. but I think it has play.Does the star gear in the door latch just spin? Mine wouldn’t latch either, pulled the door panel and hosed down the latch with PB and worked all the linkages. Got it to work after that.
Your probably doing it already but while you doing the flanges replace the pinion seals, nows the time to do itJust doing some piddly stuff while I am waiting on parts. I will list it out:
1. I got the pinion flange bolts loose on both the front and rear axle. The new flanges should be in today but I wont get to installing them untill tomorrow. I will install the drive shafts tomorrow as well.
Maybe. Try loosening the 3 big screws on the striker, it'll move a little bit. You can get to the hinge bolts easily enough if you need bigger adjustmentsI do have a question for fj55 people - I have a door that wont shut/latch all the way. is there an adjustment or fix for that?
