Rust check please! 06 Land Cruiser - half Texas half Pennsylvania
Springfield IL
Exactly as the title says, please let me know if this is worth $11k. 256k miles with all service records, single owner truck.
All I could see is the one video showing very little rust under the headlights. That's not much to go on. If this is the only body rust you've found this is good news. At your location, rust underneath would be a concern so post up some photos of the undercarriage.
If you swipe on the posted link, it has three more videos of the undercarriage
Rust wise it doesn't look too bad. There's that one spot in the rear where a piece is flaking off. Under and around the spare tire can be a trouble spot with older cruisers, not sure if this is true with a 100 but quite likely, so be sure to check there.
What service has been done? I like that it's been kept stock except for color matching front bumper.
Currently the frame is in pretty good condition, but as the paint has worn off it'll get worse quickly if it isn't treated. Get some oil sprayed under it. If you do the spraying yourself, use diluted wood tar, it's much better than oil.
