pretty easy mod,except for double nutting the studs and pulling them out of the axle housing.
i had a extra cover so i painted it and the ring ahead of time.
i also have a extra axle housing so i pulled the front set of studs from it. they are longer than the rear cover studs, so i used those.
then i applied silicone to the cover, let it sit for a couple minutes, then installed it to the housing. but the ring on and bolted it down.
i let it sit over night before filling it with 3 qts of royal purple 75/90.
after installing this and looking at it, i thought, instead of using the whole ring for one diff. why not cut it in half and use it for two. since you're only using it to protect the bottom of your diff anyway.
i have one more ring, and thats prolly what i'll do with it....
