Has anyone put the 3inch Revtek lift on their truck (FJC)? How hard was it to put on, what is the actual lift at the front, and what is the ride like. Any comments welcome. (left myself open on that one, be nice) Michael
I wanted the OME lift but, got a great deal on the Revtek lift. Will have to see what it does in the future when Bull Bar and winch are put on. Thanks for the reply's. Will post some pic's when lift is instaled. Michael![]()
One of the guys that I wheel with has a BentUp front bumper and he had the RevTek lift for a while. It seemed to handle the weight just fine (i.e. It did not appear to sag.). The ride was horrible with the spacers. He recently switch to a SkyJacker coilover suspension system and is now very happy...
the Revtek kit installs between the top of the front strut and the spring, effectively preloading the spring and taking 2+" of travel out of your suspension....expect to blow your front shocks out if you offroad the truck and top-out the suspension travel.
the Daystar kit installs with 3 longer studs above the strut and while it doesn't increase suspension travel, it also doesn't take it away.
so if I have 3" revtek lift in time I'll loos the hight? by how much?
height isn't the issue....tho the stock springs will eventually sag if you have a winch/bumper on the rig...the rig I have now (with 71,000 miles on it) does sag in the front some...big surprise with the use we put them through.
the issue is in the shock stroke....with a stock suspension the shocks are at the middle of their 8" stroke....4" up and 4" down. Because Revtek spacers install between the top of the spring and the upper coil 'bucket', they move the springs down lower in the shock stroke, giving you 6" up and 2" down...since the coils bind before the shock compresses fully, your actual travel won't even be the full 8".
(I think it's 8", don't quote it, but the theory holds...might be 8", might be 7", might be 9", but either way the stock ride height is in the middle of the shock travel)
