Build Removing SBC conversion, going back to Toyota. 1972 Frame Off
I heard the @cruiserdan and the cruiser museum is going to repo this rig!
good grief, @Jdc1 this might be the most beautiful 40 being built right now.
Just when you think someone is going to say. “Get a little Mud on the tires”...
Round one to the contender....
BTW...It is an incredible specimen...
Thanks, Ryan, that means alot. We are getting close to calling it done. There are some areas that I need to send home and a couple of things that I want to rework now that I see how everything is laying out. The details are taking some time, next to the shops work, any shortcut will be glaring.
As long as you keep the step-bit in the tool box everything will be fine!
Got some pics of the ‘72 outside today. And just for @rkymtnflyfisher moved the lockouts closer to being installed.
Blasted, etch prime and finally semigloss black and then the dials are base, clear.
Have you started to install climatisation and glass garage doors yet, this cannot be exposed to the elements anymore!
Just saying it gets better and better every time.👍
It’s been discussed. Thank you. It’s pretty fun to see the past few years of work and planning coming together.
Wow!
’nuf said 😆
Just hit 150k views. @Chungas Revenge and @rkymtnflyfisher probably account for 135k of them.
Aside from the new OEM curved corners, all of the glass in the ‘72 is new. We have been hung up on the front door vent windows. They have a hole for the pull to pass through and safety glass cannot be drilled because of the film between the layers. We finally found a shop that can do it but they are in OR and need a sample to match the color. Should have something soonish.
I was able to install the barn door latch. a few weeks ago. We did the family road-trip for Spring Break in the upgraded camper, 1300 miles. Earlier this year as we have an 8th grader that will be spending summer preparing for the HS soccer season.
